240 bulb failure relay
Old May 8, 2011 | 02:27 PM
jshaffer's Avatar
Default 240 bulb failure relay
Having trouble with my break lights I have check everything but the bulb failure relay having trouble locating it. Is it behind the steering column? this all started when the third break light shorted out and my son had smoke coming from under the dash. I have a right side stop light but no left or center. Since the the center and the left lights are not working I am assuming it may be the failure relay. They look to run together up to the failure relay so I am trying to check, but can't locate it.
Old May 9, 2011 | 01:31 AM
MasterBlaster's Avatar
Would that be a 1975, or a 1993? It might make a difference.
Old May 9, 2011 | 10:09 PM
jshaffer's Avatar
its a 1990 volvo 240 wagon
Old Sep 16, 2011 | 02:02 PM
the mechanic's Avatar
Default relay locations
here's the relay locations (will work for your car as well)
http://www.davebarton.com/pdf/relay_84_240_dash.pdf
Mar 22, 2021 10:58 AM
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
wyomingresident
Nov 16, 2008 09:52 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
