S40 skips/jumps while accelerating up hills
Old Aug 22, 2008 | 07:37 AM
cbrack's Avatar
Default S40 skips/jumps while accelerating up hills
I have a 2000 Volvo S40. It's been running great, but has suddenly began making a jumping or slight jerking motion after driving for about 20 minutes and generally going up small hills. If I decelerate, it will stop, but once I accelerate again, it will begin skipping or jumping motions. I don't feel it's related to tire balancing as it will work well for a short time at the same speed.
Old Aug 22, 2008 | 08:11 AM
Default RE: S40 skips/jumps while accelerating up hills
Last tune up? How old are the coil packs and wires?
Old Aug 28, 2008 | 11:03 AM
cbrack's Avatar
Thanks for the response.
It's been a while since I've had a full tuneup. Mainly plugs. I believe the coil packs(though I admit I don't know what they are), and wires have never been changed.
Old Aug 28, 2008 | 03:42 PM
cbrack's Avatar
Are the coil packs square parts which sit on top of the engine? Is the same as an ignition coil? If so, can you tell me how to determine if they are faulty and how to replace? Thanks,
Old Sep 2, 2008 | 08:52 AM
cbrack's Avatar
I did put in new ignition coils. Very simple process. I didn't change any wires. It still seems to skip, but the skip may have lessened. Do the wires commonly cause that issue too? Thanks,
Old Sep 2, 2008 | 03:41 PM
Christy76's Avatar
When I had coil packs changed in my Mazda MPV, they changed the spark plugs as well because they said bad coils will ruin the spark plugs.
Good luck.
Old Sep 2, 2008 | 04:05 PM
cbrack's Avatar
Great, thanks. I'll check the plugs too.
Old Sep 2, 2008 | 07:06 PM
Yes the wires commonly go bad as well.
Old Sep 11, 2008 | 12:21 PM
cbrack's Avatar
First, thanks for the help. I replaced the coils, wires and spark plugs. The problem is still there and seems to be getting worse. The car has a knocking sound when I accelerate. Once I take my foot off the gas, it stops, so I'm not sure if it's the engine, transmission or what.
Old Sep 11, 2008 | 06:26 PM
Check engine light on?
If so what are the codes?
Old Sep 12, 2008 | 10:31 AM
cbrack's Avatar
Thanks for the response. Yes, unfortunately my "check engine" light is always on. I've had it cleared many times and issues remain many aren'tcritical, but the fact is they won't go away.
As for the code, the only code which registered was P1449. Someone gave me the following definition of the code:
"The only reference to P1449 for a Volvo that I have been able to find was in regard to an 850. The code meant "Diagnostic module tank leakage - pump too high". Unfortunately, no more information was given"
Old Sep 12, 2008 | 07:39 PM
You would have to have it read by someone with the Volvo software.
torcs
Mar 10, 2014 02:52 AM
elimont
Apr 12, 2011 10:10 PM
Rekhati
Jul 27, 2010 07:40 PM
rob.mctavish
Feb 5, 2009 11:22 AM
mixpat
Jan 5, 2008 12:40 PM
