25 Amp Fuse keeps Blown
Old Dec 29, 2024 | 03:33 PM
yakitori's Avatar
Default 25 Amp Fuse keeps Blown
I have 1985 volvo 245 dl wago 2.3L M46
Recently I changed heater fan motor and resister. it was super hard for me to go through wire.
Motor fan works when dial is 0. I guess the dial 4 means off. what did I do connected wrong colors?
maybe that causing 25amp keeps blowing?
my battery is 11.40v by multimeter changed 6moth ago its low to start engine. draining electric somehow. I feel like
I brought starter and solenoid to starter pro store to fix. works fine but 25amp keeps blown. I reseal electric tape around 25 amp cable(cleaned). I checked ground wire all connected clean up.
Im wondering main fuel pump and inside pump causing issue? where is the fuel pump relay? one black relay under left side steering wheel? Engine wont turn over, starter works when battery has enough juice. 12amp blows nothing will happens.
I dont know how to test multimeter to those pump. if fuel pump is old enough they blow up 25amp fuses?
i have this car more than 10 years and never had fuel pump issue. maybe fuel pump is original. I changed fuel filter 2 years ago.
I dont know what to do next to test or buy parts to replace.
this is only car I have I need to fix it asap!
please give me some advice !! thank you !!
Looking for Volvo 240 friends in California !
Galaxy850Sunny
Oct 31, 2015 12:40 AM
KMD
Dec 3, 2013 07:32 PM
240nut
Apr 1, 2013 11:59 PM
revdevil
Jun 21, 2007 10:59 PM
vegedge
May 31, 2007 10:46 AM
