740 Power Steering Fluid
Old Oct 3, 2010 | 01:13 PM
rob2's Avatar
Default 740 Power Steering Fluid
1990 - 740
I'm topping up the power steering fluid on my 1990 740 16 valve. All my manual tells me is "Type F". The only "Type F" I recall is transmission fluid and my local car parts shop doesn't have that. Is there a specific fluid to use?
I've grown fond of my old friend and I want to use the correct fluids.
Many thanks;
Rob
Old Oct 3, 2010 | 03:06 PM
swiftjustice44's Avatar
Type F was Ford transmission fluid and has essentially been done away with...you can Dexron 3 or 4 ATF.
Old Oct 8, 2010 | 09:56 AM
Joseph/TX's Avatar
Type F is still available, mainly because there are a lot of cars that use it in their power steering. I get mine at Wal-Mart. As usual though, Swift is right; the Dexron will work and is certainly easier to find.
Old Oct 15, 2010 | 10:23 PM
Carrots's Avatar
Yup... I use Dexron in my own 740 16- valve!
oh, and if you've truly grown fond of your old friend... here's a little 16- valve advice. Stop me if you've heard this already, but if not... change your timing belt and balance shaft belt. Religiously. Every 50,000 miles- and you should change the idlers and tensioners, as well, plus the oil pump gear bolt. Yes, this is expensive on the 16- valve engine, and the parts can be hard to track down, but it's not as expensive as a valve job. The 16- valve engine is a good engine, but it's real picky about having a good timing belt that's been correctly installed.
westsacxj
Jul 13, 2017 07:50 PM
katiejoyful
Dec 12, 2007 04:49 PM
Majki
Jun 10, 2007 12:37 PM
reg
Mar 17, 2005 07:57 PM
Steamroll9
Jan 9, 2005 12:11 AM
