740 Rear Bearing Noise Identification
Old Oct 11, 2017 | 03:16 PM
peetcg's Avatar
Default 740 Rear Bearing Noise Identification
Greetings
My turbo wagon [290k] while replacing park brake cable turned the left axle which responded with 'bump bump bump bump'. Didn't think tapered bearings would do such- any knowledge of this appreciated!
Old Oct 11, 2017 | 05:34 PM
Nichals's Avatar
could it have been simply the differential gear teeth engaging?
Old Oct 11, 2017 | 11:29 PM
if the other wheel was immobilized, turning a rear wheel will cause the drive shaft to rotate at half speed assuming the transmission was in neutral. lotsa gear teeth meshing in there.
Old Oct 13, 2017 | 11:21 PM
amazonPhil's Avatar
on the 122 you change the mesh of the teeth by taking off the bcking plates and moving the shims around, Its newer but maybe not a lot different? if you take the backing plates off, dont; loose track of the shims. I was able to get lower gears that were new so I spapped the crown and pinoon to make it more like a wagon or 123 because the gearing got a bit too high when I added overdrive. doing so took a lot of the slop out of it , when they get all workn all the slop adds up to a car that will go jerky jerky gerky down athe raoad if you try to drive it at about 10 MPH in traffic.
there is a procedure where you out bluing on the gears and change those shims until you get it set up right.. if it's ok dont; play with the shims.
xjguy
Dec 11, 2010 05:15 PM
Romans510
Jul 26, 2010 12:37 PM
fdwyer
Penta
Aug 13, 2006 10:32 PM
gquodala
Feb 20, 2006 09:39 PM
RocknTommy
Apr 11, 2005 02:18 PM
