740 trans question
Old Apr 21, 2006 | 06:12 PM
ldf602's Avatar
Default 740 trans question
I have posted here before and read all trans posts, but don't remember seeing this problem. My 740 won't go into overdrive. Got advice here about changing relay and i finally did that. It still won't shift into overdrive until i have driven about 15 miles and car is good and hot.
How about taking it to a trans shop like Cottman that do free checks?
Any thoughts??? Thanks
Old Apr 21, 2006 | 09:24 PM
Default RE: 740 trans question
It might also be the Overdrive soleniod.
Or it could be a bad Transmisison.
You can try that route as well. See what they say.
Old Apr 23, 2006 | 12:45 PM
ldf602's Avatar
Sorry, some of my post got left out. A local mechanic said there was a temperature sensor in the trans somewhere, or the regular thermostat may be bad??? This winter, around the time the problems started, the temp guage began only going 1/2 way between cold and middle where it has always been since i had the car.
Any thoughts on that? Thanks
Old Apr 23, 2006 | 12:51 PM
No temp sensor in the trans.
If the guage was reading normal then nothing should be wrong.
Old Apr 24, 2006 | 05:36 PM
ldf602's Avatar
what does the overdrive solenoid look like and where is it located?
Old Apr 24, 2006 | 09:25 PM
The soledniod is mounted on the left side of the transmission about half way down it. There is a single wire coming off it and going up to the shifter.
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
