740 turbo wagon has died help
Old Aug 22, 2009 | 01:35 PM
wagoneer 1's Avatar
Default 740 turbo wagon has died help
my 1990 740 turbo wagon has died it has no power to fuel pump or injectors pump relay clicks but i get nothing does any one know where to go from here
Old Aug 25, 2009 | 11:40 AM
fredbyte's Avatar
Go to www.stepbystepvolvo.com for free guide to 740 no-starts.
Old Aug 25, 2009 | 05:57 PM
blue goose's Avatar
The first thing that happens during starter cranking is the RPM sensor (crank position sensor) puts out pulses to the ICU. That has to happen before the coil can put out a spark. Check the RPM sensor. It should be mounted at the top of the bell housing behind the engine. Sometimes the wiring gets frayed.
Old Aug 25, 2009 | 07:45 PM
TURBO 245's Avatar
Check your crank position sensor as Blue Goose suggested,but I think it's your radio suppression relay.That relay is a very common problem to 740's.The RSR applies 12v to the injectors and fuel pump relay,It's attached to your coolant overflow tank on the passenger side of the vehicle.
Dan
Ahmed
Dec 1, 2021 04:58 AM
Volvo740Bill
Apr 28, 2011 05:29 PM
d33dvb
Jan 13, 2010 10:46 PM
SunnyCatStudio
Sep 26, 2006 08:34 PM
