78 240 Vibrating Fuel Filter!? Wierd
Old Oct 12, 2011 | 05:14 PM
endneu913's Avatar
Default 78 240 Vibrating Fuel Filter!? Wierd
So, I just put a new fuel pump in my 78 ( thought thats why it wouldnt start , intermittently) Turns out the fuse was corroded...
New pump, car started up great ( didnt find the fuse till later) BUT, the Fuel filter ( new one) is vibrating like you wouldn't believe! I isolated the source of the source of the vibes as def the filter, and nothing else ( the hard and soft lines vibrate, but not as bad, and less vibes the farther away form the filter you get. Additionally, the main pump under the car does feel like it could be A source of vibrations, but not as much as the filter itself.
Additionally, With the new pump the car idles great, but will hiccup and hesitated while adding throttle, while driving, like its loosing fuel. I thought low pressure at first, but after popping off some fuel lines and having them shoot fuel non stop for several minutes, its clear that at least the tank itself is FULL of pressure. Weird.
Ive checked the relay, looks fine. Im about to try another new filter, then from there, reinstall the old pump, and see what happens.
*********update........... Went to put the old pump back in, found that the yellow wire that screws to the housing, aka the ground i assume, had somehow come loose ( the screw is sitting at the bottom of my gas tank. So... Pretty freeking wierd, how did it run at all?
The buzzing is still in full annoying effect, but after a spirited test run, it doesn't seem to be hesitating ( just once or twice, almost un noticeably in a 5 min drive )
********** Update #2... Put the old pump back in. No buzzing, no vibrations, car runs just great.
So, someone help me understand the pump system and how it works, and what in the world the difference between these 2 bosch pumps. I understand the the PSI may be different between the 2, but arent the "in tank" pumps just supposed to be "helpers" ( low psi, hi volume ) Vs the main pump being High PSI and low volume? Could it be that these 2 pumps are just mot acting in unison with one another, creating some sort of harmonic vibration? ( I just made that up
I would love to put the new pump back in, But not until I have some positive ideas on how to kick the buzzing down.
Thanks for any help!
Old Oct 12, 2011 | 11:02 PM
swiftjustice44's Avatar
Humor me...what is the country of origin on the new Bosch pump?
Old Oct 13, 2011 | 11:38 PM
endneu913's Avatar
Tis a "made in the UK" pump.... What are you thinking?
dece207
Feb 18, 2024 12:31 PM
timoc663
Aug 14, 2016 05:35 PM
acmaninaS80
Dec 6, 2010 09:34 AM
r2u
Aug 28, 2005 01:44 PM
danielribo
Apr 15, 2005 10:41 AM
