79 244. Need help to get running
Old Mar 26, 2021 | 07:45 PM
  #21
Teddi244's Avatar
Originally Posted by hoonk
I never saw a bad frequency valve - (of course last time I worked on one was maybe in 1995) it was always lack of power to it. It's a soft buzz, you might need a stethoscope, or long screwdriver on it, to hear -
I put all the parts back on and it ran pretty similar to before the o2 and fuel filter change( I think it ran poorly because the air meter was stuck, presumably because of a backfire). No noise out of the frequency valve but after some testing I found that the relay is not working properly. I jumped two of the terminals and the engine revs a bit but if I keep them jumped it dies. If I jump them on and off it revs a bit and after doing so the engine reved up with the throttle vs normally it bogs when you open the throttle only to rev a bit once you let off, by the time I had my tools cleaned out of the engine bay to test drive it it was back to its normal no rev with throttle. Cold starts still suck, I don’t thing the cold start injector or idle valve are operating.
Old Mar 27, 2021 | 08:47 PM
  #22
Teddi244's Avatar
Did some more testing today. The relay that powers the frequency valve is not getting enough voltage(1.55v) to switch it on so I jumped it and the frequency valve does work, ran the best it has since we’ve owned it unfortunately the inline pump died shortly after we left the driveway for a test drive. I also tested voltage to the cpr as well as the icv and cold start injector, the cpr is getting just under 5 volts and I’m not getting anything at the icv or cold start injector.
240driver
Sep 15, 2025 03:11 PM
rowdy646
Feb 25, 2015 11:24 AM
fochs
Dec 4, 2014 03:18 PM
feor
May 16, 2014 06:26 PM
jsmilde
Jun 24, 2013 07:17 PM
