'85 745 - starter/engine not grounded
Old Jan 13, 2008 | 05:29 PM
Juneappal's Avatar
Default '85 745 - starter/engine not grounded
The short story is that on my 1985 745 Wagon, it starts right up if I run a jumper cable from the battery negative post directly to the head. If I clip on anywhere else (chassis, various bolts in the engine compartment that are brushed clean and shiny) it will give a single tick but not turn over.
Once the car gets running, I can disconnect the battery completely and it will run fine.
It seems like the starter must not be sufficiently grounded - though it is well connected to the engine block - so the engine block itself isn't grounded.
How is that grounding normally done?
sam2010
Sep 25, 2010 07:12 PM
RedBrick
Apr 7, 2006 09:13 AM
judydiane
Mar 15, 2006 01:24 AM
merian
Nov 7, 2005 01:39 AM
caliveltz
Feb 19, 2005 08:51 PM
