87 240 no start
Old Mar 10, 2009 | 02:17 PM
comptronix's Avatar
Default 87 240 no start
On Friday I backed up and the car died then when I tried to restart it it only turned over.
Here is what I have done and checked
Gets spark
Timing belt fine
Fuel pump fuse OK
Fuel pump relay looks fine but when I jumper it like described in the haynes
manual the fuel pumps do not come on.
I then jumpered the fuel pumps at the fuse box as described in the haynes manual and both fuel pumps come on.
So I figured if the pumps are running the car should at least try to start but no such luck.
anyone have a clue what could be wrong
Old Mar 10, 2009 | 04:24 PM
bubba240's Avatar
Sounds like a bad 20A fuse by the battery, the fuel pump relay, or the ignition switch - measure the voltage on the red, and the red-black wire at the pump relay.
Old Mar 10, 2009 | 08:14 PM
fredbyte's Avatar
Does this have a radio suppression relay like the 740? Go to www.stepbystepvolvo.com for free guide to 740 no-starts. May help you with the 240.
Old Mar 11, 2009 | 09:59 AM
bubba240's Avatar
no radio suppression relays on 240's ...
Old Mar 11, 2009 | 04:57 PM
comptronix's Avatar
Question still not working
Thanks,
The other day I disconnected the 20A fuse wire because it looked like it was used for the radio. Now that I have the wire back together my fuel pump relay opens and closes , fuel pump both come on , but still no start.
Old Mar 11, 2009 | 05:36 PM
bubba240's Avatar
That relay contains a second "system relay", make sure its working by measuring the voltage on the air mass meter orange wire. You should also see AC volts on the green-white injectors wires, suggesting the fuel ECU is being powered and opening the injectors.
If that all checks out and you still have spark then maybe check compression.
Old Mar 13, 2009 | 06:27 PM
comptronix's Avatar
Question
OK I checked all the electric and everything had power.
Mechanic told me to pure a little gas into the hose after the mass airflow sensor and the car did try to start.
Mechanic thinks its the distributor. can anyone confirm this would hate to buy a new one just to figure out thats not it.
Old Mar 14, 2009 | 08:23 AM
gforce's Avatar
Comptronix,
my 91 740 died while i was driving, i checked everything as you have done, finally sent to mechanic --- it was distibuter cap and roater -- i was getting spark but it was week so she would not start -- replaced and she is still running strong a year later. TIPSP and bubba 240 are very intel. on volvos they have helped me in the past, try there advice first, if they suggest otherwise.
DecalService
Dec 4, 2019 10:52 PM
MMAFIGHTER
Sep 2, 2008 08:43 PM
WagHag
Dec 2, 2007 08:45 AM
auser
Nov 20, 2004 10:27 AM
