87 LH 2.2 740GL Hard Cold Start
Old Mar 17, 2020 | 06:55 PM
SLT16's Avatar
Default 87 LH 2.2 740GL Hard Cold Start
Hi all,
I've got a very hard cold start on my 740. When the car is slightly warm or at operating temp, it starts up in 2 secs. When i try to start it first thing in the morning, it cranks very hard and once it actually comes to life the RPM stutter quite a lot for a couple of seconds like the car is about to stall, until the car goes to normal idle RPM. If you shut it down right after that and try start it up again, it will start up first try in 1 second.
I've replaced the coolant temperature sensor, cleaned the throttle body, there are no vacuum leaks, also done the fuel pump check valve and the fuel filter. The external fuel pump is fully functional and so is the FPR. I am suspecting there is no fuel pressure at startup, but how can this be since i've replaced the check valve? Just to note, the MAF is not the problem.
I'm not sure if this has something to do with the harness, as i'm aware of the problems with the biodegradable harnesses but i don't actually know of a way to test this?
Any help would be appreciated.
Old Mar 17, 2020 | 06:57 PM
SLT16's Avatar
Also I've had the distributor, all spark plugs and leads replaced 2 years ago. Shouldn't be a problem.
Old Apr 13, 2023 | 01:08 PM
760V6Tank's Avatar
Default Did you have any luck fixing this issue?
Hi mate,
Just wondering if you were ever able to solve this problem at all? I have EXACTLY the same issue with my Volvo 760- really curious as I desperately want to solve it!
Cheers!
Old Apr 16, 2023 | 03:34 AM
SLT16's Avatar
Originally Posted by 760V6Tank
Hi mate,
Cheers!
It ended up being the ECU. Swapped it over and it fixed everything.
Roger M
Nov 27, 2019 12:38 PM
Tallbison
1998-2000 model year V70
Aug 24, 2018 08:56 AM
badrad
Jun 11, 2012 10:43 PM
volvoguy2323
Sep 24, 2011 01:13 PM
coolson
Dec 10, 2010 12:35 PM
