'89 740 Hamonic Balancer
Old May 1, 2008 | 07:36 AM
dadto5's Avatar
Default '89 740 Hamonic Balancer
How much play fore/aft should there be in the the harmonic balancer? I know it's not the crank or the crank pulley. It's moving far enough back to rub on the cover for the timing belt.
How do I pull it. I assume at first glance that I remove the bolt and us a puller.
Old May 1, 2008 | 10:11 AM
jonesg's Avatar
Default RE: '89 740 Hamonic Balancer
Heres how I did mine, disconnect ignition coil.
Put wrench on crank bolt and brace it against the car frame, blip the starter for a second and the bolt can be removed by hand. Work the pulley off with 2 screwdrivers .
Old May 24, 2008 | 01:58 AM
dadto5's Avatar
ORIGINAL: jonesg
Worked, except the screw drivers. The 7lb sledge didn't work either. Nor did the 3' crow bar. but my 94 E350 did.......
You might be a red neck if.....[&:] you attach a come-a-long to the trailer hitch of your van and around the crank pully and start pulling.
Had enough tention on the line that the whole wagon slid in the grass. I was going to take a picture but one good hit with the sledge and that pully came flying off.[:-]
O-well that jobs done and I have a great story to boot.
catpressedjeenz
Aug 20, 2010 09:19 AM
lummert
Feb 22, 2008 04:45 PM
simeyrocks
Jan 26, 2008 09:02 AM
bli745
Jun 4, 2007 06:11 PM
RocknTommy
Jul 22, 2005 09:44 PM
