'90 240 idle control motor question
Old Nov 24, 2006 | 03:31 PM
montysano's Avatar
Default '90 240 idle control motor question
Hello once again,
My '90 240, it had a non-stock hose running from the throttle body to the idle control motor. Someone then put a hose clamp on this hose; constricting the hose via the clamp achieves the right idle speed. If I put a stock hose on, it idles way too high. So, I'm assuming a problem in the idle control motor. Would ya'll agree?
The idle control motor has an aperture in it, which I assume varies the amount of air. Should I be able to move this by hand? Mine won't move at all by hand. Is this a serviceable item? My manual makes no reference to this.
Thanks,
monty
Old Nov 25, 2006 | 11:39 PM
Default RE: '90 240 idle control motor question
You should be able to move the motor with a pick.
Also if the throttle body is out of adjustment the car won't idle correct.
newmex999
Apr 24, 2015 09:22 PM
jigen3
Feb 27, 2015 05:58 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
montysano
Jan 12, 2008 12:39 PM
derrro
Jun 8, 2007 02:47 AM
