90 245 Fuel pump issue
Old Oct 22, 2007 | 08:01 PM
v8 volvo's Avatar
Default 90 245 Fuel pump issue
I have a 90 245 that developed a fuel issue after being parked for a few months. Prior to that, it always started instantly. I popped the cover on the ECU/Fuel PumpRelay, and manually toggled the fuel pump relay, which enabled the car to run if held continuously. The relay coil has continuity and there are no cold solder joints. I found the two ground wires on the fuel rail to be crusty, so I cleaned them up and put new terminals on, but that didn't fix the problem. Any ideas??
Old Oct 22, 2007 | 09:28 PM
blue goose's Avatar
Default RE: 90 245 Fuel pump issue
Other than a "fuel issue," it's not clear what the problem is. If you haven't done so I would replace the fuel filter. Car sitting for a few months = cruddy gas = clogged up fuel filter.
Old Oct 26, 2007 | 06:58 PM
outofworkjoe's Avatar
Try replaceing the fuel pump relay frist.
volvoplay
Jul 16, 2012 07:03 PM
spidersilva
Aug 17, 2011 07:23 PM
treybohon
May 19, 2010 02:41 PM
orcutd
Sep 27, 2008 08:13 PM
