91 240 Braking Issue - MC? Vac? BBooster? Pls Help
Old May 18, 2014 | 12:10 PM
pete77gg's Avatar
Default 91 240 Braking Issue - MC? Vac? BBooster? Pls Help
Hi, 1991 Volvo 240 Auto Base Model Non-Abs.
I've been having an intermittent issue with my braking and am hoping someone has had a similar issue or can point me in the right direction....
Once in a while when I depress the brakes the pedal travels to the floor...release brake and depress and full braking again. right away thinking it's the Master Cylinder by not 100% sure as:
1. This happens with no discernible pattern (ie gets better & worse over time) and temperature, amount of braking, length of trip, length of issue persisting - none of it seems to be consistent. Some days / week no issue whatsoever, then one day have 3 - 4 episodes.
2. I may be crazy but if any pattern, seems to happen more when I travel downhill for a period or after a period of extended steady acceleration?
3. If I stand on the brakes when no issue is apparent, it doesn't seem to diminish and the pedal stays firm...
4. Has been going on infrequently over the past 6 months and don't think it has gotten any better worse, just still happens from time to time (Not an easy feeling driving sometimes so yes, need to address)
5. Not losing any fluid
Thinking master cyl. but then think also may be a Vacuum problem or booster issue? Wheel Cylinder?
Appreciate any advice as want to fix but don't want to just start throwing parts at it (but if going to do it, do it right & not just put master cyl on to find after bleeding etc. it was booster all along)
Old May 18, 2014 | 01:02 PM
lev's Avatar
lev
It is the master cylinder, really, can't be anything else... Booster failure won't cause the pedal to go to the floor.
Old May 18, 2014 | 05:00 PM
guest01's Avatar
Are you losing brake fluid?
Old May 19, 2014 | 05:21 PM
240-FAN's Avatar
Its your master cylinder. had the exact same symptoms on same model year 244. Lost brakes in the middle of Chicago and then had to replace it in a autozone parking lot.
Its simple. Shouldnt take you more than an hour plus whatever time to bleed brakes.
dawagner93
Apr 28, 2015 07:21 AM
cano1986
Jun 28, 2014 07:54 AM
240classic
May 28, 2011 06:02 PM
bne
Jan 28, 2006 05:00 PM
