91 240 fuel injector ground
Hello all, I'm trying to diagnose and issue in my 240 where its a crank no start. It sparks but seems to be getting no fuel. When I first took the 2 bolts of the fuel rail it started. Now one of the ground wires causes it to sometimes start or not. I cleaned it, sometimes it will spark off the end by the bold when I crank it. The fuel pump relay also buzzes Any ideas?
Check that the engine harness is getting a good ground at the fuel rail/intake manifold.
Try this guide: No Crank or No Start - Turbobricks Forums
It's sparking off the end of the bolt grounding the engine harness???
fuel injectors on a 240 get their power from the fuel system relay near the glovebox. all 4 injectors are wired in parallel, they get the same relay-switched power, and the ECU 'grounds' all 4 at the same time to fire them.
best way to test the electrics of EFI is a 'noid light', this plugs into the injector harness and the injector, and blinks when the injector is fired.
xDread92x
09-19-2014 09:15 AM
