hesitation between 1500-2500rpm
Old Mar 5, 2009 | 09:58 AM
bowes73's Avatar
Default hesitation between 1500-2500rpm
I have a hesitation between 1500-2500rpm and the problem seems to be getting worse. The problem goes away under hard acceleration. I put in new spark plugs but it did not help. I'd like to fix the problem myself but am not sure where to begin. I've thought about replacing the ignition coils ($250 +) but hate to do so if they are not the problem. Does anyone have any suggestions or instructions on how to test the coils?
Thanks,
Richard
Old Mar 12, 2009 | 06:18 PM
christopherallen's Avatar
bump i would like to know about this as well
Old Oct 12, 2009 | 09:56 AM
thedigid's Avatar
Default did you find a solution to this?
I have a 99 s70 glt and I'm getting hesitation between 1500-2500rpm when the engine is cold. It slowly goes away.
Did you find a solution?
Old Mar 15, 2013 | 09:26 PM
Pej's Avatar
Pej
Default Bringing this one back
Anything on this issue? It feels like after 1500rpm I get a misfire or so, I believe it's one of my coils as my mechanic always said to me the coils tend to go on these cars.
No engine light yet, wish I had one so I could do a code-pull. And the problem seems more prominent while the car is colder or the first hour of driving, after a while it goes away.
New Plugs, New Head. I think it's the coil in my case.
Any insight would be nice.
Old Mar 17, 2013 | 12:54 AM
gdog's Avatar
Most likely need an ETM; suggest you look at xemodex.
Old Mar 17, 2013 | 03:26 AM
Pej's Avatar
Pej
Are you sure about that?
Don't tell me that, that's another 500 dollars plus labour. Apparently my mechanic cleaned it while he had the head out.
Old Apr 3, 2013 | 01:52 PM
yoyoman's Avatar
I am having a similar hesitation issue now too. My problem started after my most recent oil filter change + top off of 1 qt of oil per the auto-rx sludge removal instructions, Fast Track Engine Sludge and Oil Burning Instructions using Auto-Rx Internal Engine Cleaner.
The car seems to stutter at the low rpm and then it will surge a bit and then settle back down. Not sure why an oil change would cause such a problem ...
Cris van Hoogstraten
Oct 22, 2014 11:50 AM
greasedlightning
Jul 14, 2010 10:45 PM
sia
Sep 7, 2008 04:27 PM
BorninBflo
Jun 30, 2008 10:58 AM
gendy
Jul 17, 2006 02:22 PM
