91 740 radio removal
Old Jan 16, 2008 | 08:35 AM
sullystull's Avatar
Default 91 740 radio removal
Is there a special radio removal tool to take out the radio or can a simple small flat head screwdriver work?
Old Jan 17, 2008 | 05:45 AM
gforce's Avatar
Default RE: 91 740 radio removal
I took a coat hanger and cut two sections, then I put 1/8" L bends in one end of each. You should be able to slid into slots with L facing down and "hook" the radio. Be sure to get your radio code you will need it when reinstalled.
Good luck--- from fellow 1991 740 owner.
Old Jan 17, 2008 | 05:22 PM
colgate41's Avatar
That sounds good, almost like pullers that come with most new aftermarket stereos. Just be carefull with the plastic....one wrong move and CRACK. Good Luck!
Old Apr 8, 2008 | 09:58 PM
brutus's Avatar
When did Volvo start using radio coades?
surfonly
May 20, 2007 07:49 PM
Irollinwichita
May 1, 2007 11:01 PM
99s80t6
Apr 15, 2006 08:22 AM
pisque
Aug 3, 2005 03:14 AM
whyflygti
Apr 21, 2005 04:43 PM
