92 240 timing belt broke
Old Jan 5, 2011 | 12:54 AM
Alaska 850's Avatar
Default 92 240 timing belt broke
Is this an interference engine, please? I don't think so, but it has been 10 years since I have done a belt on one of these. Thanks
Old Jan 5, 2011 | 05:36 AM
NCVOLVO940's Avatar
you're safe!
Old Jan 5, 2011 | 08:28 AM
jagtoes's Avatar
Yes it is so when the belt broke you most likely bent a few valves. You could either put on a new belt and then do a compression test or pull the cam cover and cam and pump compressed air into each cylinder and see if it holds pressure. Use a leak down tester to do this.
Old Jan 5, 2011 | 09:32 AM
bubba240's Avatar
The B230F engines used in the 240's are non-interference. Look at other posts on this forum where the belt has broke.
Old Jan 5, 2011 | 09:35 AM
adki110's Avatar
Single cam engines are non-interference - double cam engines are interference.
Old Jan 5, 2011 | 12:41 PM
jagtoes's Avatar
Sorry wrong block.
Old Jan 7, 2011 | 04:18 PM
Alaska 850's Avatar
Thanks Everyone! I am driving 100 miles to put a new belt, tensioner, and waterpump on. I didn't wat to do it out in her driveway at 20 degrees if I would have to deal with bent valves, and pulling the head.
darimik
Jun 28, 2009 07:32 AM
vances70
Jan 13, 2008 03:46 AM
pos960
May 2, 2007 12:57 AM
Verum
Jul 4, 2006 04:55 PM
carol
Mar 6, 2006 09:53 PM
