94' 940 problems
Old Jan 31, 2007 | 09:00 PM
  #21
Default RE: 94' 940 problems
I have also seen the computers bad on theses cars cause the same problem.
Old Jan 31, 2007 | 10:03 PM
  #22
loonatic72's Avatar
Well I just went out and I guess the car wasn't cold enough to give me problems starting but while it was running I fiddled with the tps. Can you usually unplug it completely with it stalling? But I hit the throttle and wiggled the connector of the tps and every once and a while it would stop stumbling. It did have electical tape around the bottom of the connector so I pulled that off and the wires all looked good. Is there a way I can test the wires and maybe ohm the sensor??
Old Feb 1, 2007 | 08:34 PM
  #23
You can ohm the sensor but I don't have the specs here.
From what I remember you can run the car with it unplugged.
It only tells the idle motor whe to turn on.
hotsh0t5
Feb 13, 2011 10:40 PM
ogotaj
Mar 22, 2008 02:57 AM
matts8008
Sep 7, 2005 10:49 PM
VolvoNewbie
Nov 7, 2004 10:21 PM
volvo13
Oct 9, 2003 01:36 AM
