94 Volvo 940 turbo will not start! Need Help!
Old Nov 10, 2008 | 04:49 PM
spider's Avatar
Default 94 Volvo 940 turbo will not start! Need Help!
Hello To All. I have no power to the primery ignition coil and no voltage on the fuel pump fuses. I measured the voltagewith the ignition key in the start/run position. I believe it is the Igniton Control Module. I found one on ebay but it wil not work if the vehical has an EGR valve. I do not know if the car has an EGR valve. The 94 940 turbo 4cyl only has 250,000 miles. Can any one offer anyhelp? I have spent days working on it. Thanks
Old Nov 10, 2008 | 08:13 PM
Default RE: 94 Volvo 940 turbo will not start! Need Help!
You measured voltage when the key first turned on? The fuel pump will only have power for a few seconds.
Do you hear the relay clicking when turning the key on?
Do you have injector pulse?
You might have a bad engine speed sensor as well as an injector relay.
Old Nov 10, 2008 | 09:12 PM
fredbyte's Avatar
Go to www.stepbystepvolvo.com for free guide to (mainly 740)/(some 940) no-starts.
techmantrey
Feb 6, 2015 03:19 AM
940glowner
Dec 12, 2013 10:45 AM
jelarf
Oct 29, 2012 09:37 AM
jcraig0433
Apr 12, 2009 03:18 AM
ogotaj
Mar 22, 2008 02:57 AM
