940 Cluster woes
Old Aug 5, 2012 | 08:14 PM
PAVolvo850's Avatar
Default 940 Cluster woes
The speedometer previously was jumping on my 92 940 turbo sedan, so I removed it and gave it a good once over "inspection" for any obvious bum solder joints and found none. I put it back in and it worked fine.. This led me to believe perhaps a plug was corroded or loose.
Well, now the speedo died completely and the overdrive light does not work as well. So I decided to look into a pro shop repair. I got a quote from Southern Electronics in VA for 275 total parts and labour, including a one year hassle free warranty.
I think I'm going to go this route, but I was wondering if anyone here has used these folks to get work done, and if they did a good job.
I'm aware one could go over all the solder joints and such, but I'm all thumbs and like the idea of a warranty if someone else messes things up.
Hollander says only 91 and 92 740 and 940 turbo clusters will swap. I cant find another so I may as well bite the bullet and get it fixed for real. Any experiences you could pass along would be great, thanks!
Cheers,
Mike
Old Aug 7, 2012 | 04:53 AM
91-740Turbo's Avatar
I had a different problem with my 740. I would be doing 90 mph with the transmission in park. What I have found out is that when Volvo came out with the cars that year, they had sub-par electronic parts. My circuit board on the back was corroded (and still is, will get that done soon) but the main problem was the capacitors being bad. But $275 from someone that does that sounds better than what I have seen for my car (about $300-350).
Old Aug 8, 2012 | 10:17 PM
swiftjustice44's Avatar
Or...pull one from a salvage car. The vast majority of these cars go to the scrap yard with functioning speedos.
Old Aug 9, 2012 | 07:14 AM
PAVolvo850's Avatar
Unfortunately there is only one turbo car in the yard.. It's an 87. I wonder if a swap year (91-92) na dash would work, lacking only the mechanical boost gauge? I'm installing an aftermarket boost gauge anyway. Any word on this option? Thx.
Cheers, mike
Old Aug 9, 2012 | 08:56 AM
I don't see why it wouldn't. Probably best to study the connectors on the back side first. And...if they are constructed like the earlier version (83-89), there will be a knock out to install your existing factory boost gauge.
Old Aug 9, 2012 | 09:16 PM
PAVolvo850's Avatar
I think I'm going to give it a go if I can find the correct year an dash.. I'm surprised no one else has tried this.. Cheers, mike
Old Aug 10, 2012 | 02:49 AM
just don't connect the red-white wire to a instrument panel that doesnt have a tach
Old Aug 11, 2012 | 09:19 AM
lev's Avatar
lev
Just swap the speedo! You don't need the whole panel. All 1991-92 740/940 will interchange just fine...
BTW, they ALL have a TACH unless by some fluke you run into a Euro model.
Old Aug 11, 2012 | 10:31 PM
And normally the speedometer would have the odometer on it as well, so if you get a speedometer from a salvage yard, you will have to adjust the odometer and file the proper paper work to the Department of Transportation (or something like that).
Old Aug 11, 2012 | 10:34 PM
don't turbo and non-turbo and abs vs non-abs have different tone rings?
Old Aug 11, 2012 | 10:56 PM
The difference is only between abs and non-abs. Pretty sure abs was standard by 91, certainly by 92.
Old Aug 12, 2012 | 12:21 AM
lev's Avatar
lev
The mileage disclosure only applies to models LESS than 10 years old. Nobody cares about cars as old as 1992s...
Old Aug 13, 2012 | 04:33 AM
Ok then, that clears that up.
Old Aug 13, 2012 | 05:41 AM
I browsed the california vehicle code sections on this.... It appears to me (I am not a lawyer) the DMV doesn't need the mileage on registration papers on vehicles over 10 years old, however, the laws regarding speedometer changes, and putting a sticker on the door frame if the speedo is incorrect have no such 10 year limit.
every states vehicle code specifics vary some
Old Aug 14, 2012 | 12:30 AM
lev's Avatar
lev
Cars 10 years old are EXEMPT from mileage reporting.
Still, with Carfax and such, the mileage gets reported ***** nilly but it is nor required. For resale purposes mainly you don't want to have a car that had 200k, then 150k.. doesn't look good.
scrumblero
Oct 27, 2014 12:08 PM
PAVolvo850
Jul 15, 2012 05:40 AM
Shel1555
Jul 2, 2012 11:03 PM
volvo5volvo
May 29, 2012 05:46 AM
WalterXI
Jul 4, 2011 09:56 AM
