940 D24TIC to B230F
Old Jun 3, 2018 | 07:05 AM
Taavet Hansen's Avatar
Default 940 D24TIC to B230F
Hello
I have a 1994 940 sedan with D24TIC and M46. I wish to swap it to B230F. Google did not do me any good so I want to ask which parts do I need off the donor car to make this swap work?
Old Jun 3, 2018 | 02:49 PM
phew. at a minimum...
nearly everything under the hood including wiring harnesses, relays, airbox, etc. ecu and icu which are behind the firewall under the dash. fuel pumps. if you're keeping the M46, you'll need a B230F from a manual, or you'll need to find a flywheel to replace the automatic flexdisk, and if your B230F is 1989+ so uses LH2.4 (preferred), then this flywheel should also be 1989+ as LH2.4 needs timing dings in the flywheel. exhaust system including cat and o2 sensor.
the diesel probably has a different final drive ratio, you'll want to change out the gearing in the rear axle (parts from donor car). if instead you go with the transmission from the donor car (probably an AW70/AW71 automatic), then be sure to get the drive axle (different lengths for different trannies) and shift linkage and interior trim around shifter.
assuming the B230F donor car is also a 940 (or 91/92 740), you'll want the relay panel under the center console, and 'merge' the EFI relay stuff with the stuff your car already has (unless the cars are identical years and have the same 'features', you likely can't juist take the donor relay panel as-is). also if you're switching to the AW70/71 automatic, you'll need to change out the OD relay and wiring as they are different between an automatic and manual.
assuming donor car is another 940, swap the front springs, the diesel has super heavy duty springs which will ride like a rock with the lighter gas engine.
outriding
Nov 2, 2017 04:57 PM
BlackHearse
Nov 30, 2015 05:26 AM
AlexMacDonald
Feb 10, 2015 07:55 PM
fritzsch
Feb 25, 2013 12:34 AM
92_940
Feb 5, 2012 02:46 PM
