940 O2 sensor
Old Nov 9, 2014 | 11:11 AM
Whodda's Avatar
Default 940 O2 sensor
As I have yet to get off my lazy **** and pick up a manual.... can any one of you fine ppl assist me with a PN for the O2 sensor for a 1994 940 non turbo? or send me in the right direction?
Thanks in advance
Tim
Old Nov 10, 2014 | 09:13 AM
lev's Avatar
lev
Lots of good info here:
https://www.google.com/search?q=volv...x-a&channel=sb
Old Nov 10, 2014 | 08:49 PM
94 940 regina = 3547445
94 940 bosch lh2.4 = 9135793
94 940 bosch w/ pulseair = 9135795
94 940 bosch turbo w/o EGR 9135794
94 940 bosch turbo w/ EGR 9135621
see? its never that simple. these PN's are all from the 2003 edition of the Volvo VADIS parts catalog.
Old Nov 11, 2014 | 12:46 PM
Whodda's Avatar
Thank you so much Pierce.....Uncle Sam didn't afford me the time to come back yesterday and edit my info stating I have the lh2.4
Old Nov 11, 2014 | 01:26 PM
The real Volvo ones are like $250 or something stupid.
I'd probably get this one, assuming your car is non-EGR
https://www.fcpeuro.com/products/vol...-w-o-egr-13380
with EGR, this
https://www.fcpeuro.com/products/vol...with-egr-13378
Old Nov 11, 2014 | 05:21 PM
lev's Avatar
lev
Actually for non Reginas you can use Ford spec Bosch O2 sensors, $25 at Autozone and such. The plug has to be swapped, but if you don't mind that, it is a cheap option.
Old Nov 11, 2014 | 05:30 PM
i never noticed before that volvo had so many different PN's for sensors... those two from fcpeuro are specied for 94/95 940 (bosch) only, and different for EGR vs not.
my 92, there's different PN's for turbo and not turbo... 3531400 for turbo, and 3501753 for non-turbo bosch.
Old Nov 11, 2014 | 06:59 PM
Whodda's Avatar
That is another reason I asked you experts...I noticed the many different sensors and was like WTF... At least I have it narrowed down.
Thank you Lev for the Ford tip.
Old Nov 15, 2021 | 10:21 AM
wyoben's Avatar
Default Dead Thread? Dead Volvo ! H-E-L-P ?
Howdy, I know this is a really OLD thread but here goes ... I was out 4- wheeling with my Battle-Ax 940 , and was crossing a small creek , actually on the return ...anyway the ex. pipe ripped off and caused the warm/hot O2 sensor to take on water ... perhaps it cracked the ceramic and failed , Long Story ! What I'm wondering is if anyone can tell me the FORD sensor part I can replace it with cheaper . Mine is a simple 2 wire O2 sensor 1994 volvo no turbo and W/ EGR Thanks Guys !
Old Nov 15, 2021 | 10:35 AM
lev's Avatar
lev
Generics. You can install a generic Bosch or other three-wire heated sensor instead of the more expensive Volvo OEM sensor in Bosch LH systems, but you will have to splice in the connector. The separate FAQ File on sensor replacements shows some wire length and splice information. Bosch model numbers 13953, 13942, and 13913 are reputed to work depending on your year and engine (same sensor listed as for Ford 5.0 V8 Mustang engine but different harness lengths: check the Bosch site for applications and see the FAQ File on sensor replacements).
Old Nov 15, 2021 | 10:48 AM
+1. I've done this for two cars including an 850T and it worked out well (which has a four wire connector so you have to pay attention to what's the heater vs the sensor). The kits will come with heat shrink insulation so my advise is to disconnect the connector, pull out the sensor, do your cut/splice on the bench to get the correct length then reinstall like its a new part.
Old Nov 16, 2021 | 11:12 PM
wyoben's Avatar
I'm wondering if the Generic Eric O2 sensor aka Ford V-8 Bosch 13942 ,is going to work with 1994 940 engine code " 83 " W/ Pulseair EGR .I have a spliced in O2 sensor in it now, that has been running a long time ...to the best of my knowledge it is part # Bosch ? 252 003 034 ? other numbers on it are 982 , 92732. this was a replacement spliced in unit ,that has run fine ...until water contamination ...I'm curios to know if the Ford unit will work 100%.I dont mind splicing the wires etc, just want to do it cheap as possible ...THANKS .
soduku007
Oct 7, 2019 04:01 PM
ruggles
Mar 3, 2010 04:19 PM
mctan
Feb 2, 2010 03:16 AM
Scanman
Jan 28, 2010 07:01 PM
sabydady
Jul 7, 2009 04:58 PM
