940 Turbo '93 transmission
Old Apr 18, 2011 | 01:32 PM
p0shr's Avatar
Exclamation 940 Turbo '93 transmission
She doesn't go into 2nd without a lot of seemingly unnecessarty revving and then with a slight jerk.
Can this be corrected by adjusting something?
Old Apr 18, 2011 | 07:36 PM
swiftjustice44's Avatar
The transmission is an AW71, an exceptionally durable transmission. There is a remote possibility that adjusting the kickdown cable may help...but revving between shifts is generally not good. Check your manual or Google how to adjust it. Basically, it is attached to the throttle spool and you turn the locking nut one way or the other to adjust. Before completely writing the transmission off, you could change the filter and fluid. If you do end up going for another transmission, do NOT install an AW70 from a non-turbo car. While they look the same externally, an AW70 can not withstand the extra torque of the turbo motor. I tried it...the AW70 lasted exactly 2 weeks!
Old Apr 19, 2011 | 09:35 AM
p0shr's Avatar
Thanks, swiftjustice44.
jeffrisley
Jun 14, 2015 01:48 PM
92_240_sedan
May 14, 2013 11:47 AM
cosmo
Nov 24, 2009 04:37 AM
mcmuggles
Feb 25, 2009 11:54 PM
ogotaj
Mar 22, 2008 02:57 AM
