940 wagon AC
Old Mar 23, 2008 | 08:19 AM
240nc's Avatar
Default 940 wagon AC
Friend just bought a 94 940 Turbo wagon. AC not working has basic controls. System has charge no compressor engagment.
Anyone have a basic tree of troubleshooting .... where to start looking for problem?
Thanks in advance
Dave
Old Mar 23, 2008 | 08:32 AM
Default RE: 940 wagon AC
Check for power at the low pressure switch.
If no power then I would remove the control panel and opne it up looking for a bad solder joint.
The bad solder joint is very common on that car.
I have been trying to find an old controller to take apart at home to make a walkthrough for the forum.
Old Mar 23, 2008 | 08:50 AM
240nc's Avatar
Tech, you are refering to the center control panel, correct? and once removed where should I look for this bad joint? I have aldata CD's so I can bring up complete wiring .... just need a little more info on the joint... where it would be?
Old Mar 23, 2008 | 09:10 AM
Once the unit is out you need to remove the black cover by folding up the metal tabs.
Then take out the 2 screws from the outside going into the plastic by the plug area.
Then uder where the cover was remove the 4 screws. Then the circuit board will flip over.
Then look closely and you should see the bad joint.
If you don't and can post a pic of the circuit board I can point it out to you.
pierce
Dec 10, 2010 02:08 PM
ogotaj
Mar 22, 2008 02:57 AM
gtf8326
Jul 1, 2005 10:45 PM
gtf8326
Jul 1, 2005 09:49 PM
GaryBrad
Mar 28, 2005 02:37 PM
