960 engine mounts in 740
Old Oct 13, 2021 | 10:57 AM
Oldvolvoguy740's Avatar
Default 960 engine mounts in 740
Volvo newbie here. I just purchased a beautiful 1991 740 sedan and have begun repairing all mechanical issues. I replaced the engine mounts with Westar #Em8622 because I could not find oem mounts. The Westar mounts are stiff and the car vibrates at idle. The old oem mounts were worn pretty badly and oil pan was close to the sway bar, but I had no vibration before mount installation. Has anyone here actually installed 960 oem mounts in a 740? They are available and if will work might be the answer to my issue. Thank you. John
Old Oct 13, 2021 | 04:37 PM
lev's Avatar
lev
Why not just get 740 mounts? They are not hard to find. I don't know if anyone can help you with 960 mounts in a 740 question. If you have vibration now, obviously the mounts you put in are not right.
Old Oct 13, 2021 | 07:35 PM
I have had no luck finding oem 740 mounts for My 91. Any idea where I might find a pair? From my research it looks like volvo discontinued them and I couldn't find any on line anywhere. I was just curious if anyone had installed 960 mounts because they look similar. I will keep looking for a set of oe volvo 740 mounts. Thank you.
Old Oct 13, 2021 | 09:55 PM
lev's Avatar
lev
960 mounts seem to be different. 740 mounts could be just rubber or the oil filled kind in the later models. I'd try a good aftermarket set if you can't find OEM ones.
Old Oct 14, 2021 | 04:06 AM
Thank you. 😊 I appreciate your insight. John
Old Oct 14, 2021 | 06:53 AM
jagtoes's Avatar
If you google Volvo 740 engine mounts you can find many suppliers of them .
billp
Jun 11, 2013 11:13 AM
HummerGuy
Jun 30, 2011 03:10 AM
Sofar.
Jun 4, 2009 09:23 PM
sharifsm
Dec 28, 2006 02:00 PM
moet32
Sep 23, 2005 02:34 AM
