ac question
Old 07-21-2018, 01:04 PM
bigarms24's Avatar
Default ac question
I have a 88 240 and live in az and I was wondering what all componments it needs to make it actually have working ac I see that it has a compressor but that's all I see
Old 07-21-2018, 02:14 PM
tony1963's Avatar
I've been a bit concerned about answering AC questions lately because working on them is not recommended for the novice. If you do not have a refrigeration certification, I do not recommend doing any DIY type work.
However, in the interest of information, an automotive AC system has the following components:
COMPRESSOR - to compress low pressure gas into a high pressure gas
CONDENSER - to take the high pressure gas and remove heat
EXPANSION DEVICE - to take the low pressure liquid after removing the heat and meter it into a low pressure gas
EVAPORATOR - to take the low pressure gas and absorb heat from the interior cabin
Of course, there are the appropriate amount of seals and lines and NO, you can't run garden hose in place of the proper hose. On the high side, you can have pressures over 400 lbs sq in. That's dangerous.
You need to seek the help of a professional to get yours going again.
Old 07-21-2018, 06:01 PM
bigarms24's Avatar
I figure id have a professional intall and charge it but I may start to collect parts
Old 07-21-2018, 06:52 PM
jagtoes's Avatar
Is there an existing system left on the car. Before you start buying stuff I would assume that you inventory what you have and then determine what needs to be replaced. These cars had very simple AC systems and there is no complexity for a DIY'er to install/replace components. Once you get the existing system flushed and install the replacement parts then if you are not comfortable with vacuum leak testing and refilling with freon then take it to someone who does this. You need to follow some standard safety precautions but that is only when you need to refill it. Check out some of the youtube videos just to get familiar with various systems.
Old 07-22-2018, 12:04 AM
bigarms24's Avatar
I haven't taken inventory I just was wondering what all it would take I have no idea what a stock setup complete looks like I usually just melt through summer and got curious
Old 07-22-2018, 09:48 AM
jagtoes's Avatar
Take several pictures of your engine compartment and post them here. Should be enough people here to see what you have and what you need.
Old 07-22-2018, 12:00 PM
bigarms24's Avatar
ok thanks ill do that
SPANK
06-25-2012 04:23 PM
amazon2
09-10-2011 11:49 AM
zloetakoe
08-08-2011 07:31 PM
S802001
03-29-2010 08:54 AM
summit
12-13-2008 09:50 AM
Quick Reply: ac question
