Air Bag Clockspring
Old Mar 3, 2019 | 08:46 PM
amazon2's Avatar
Default Air Bag Clockspring
I was "pretty careful" when removing the steering wheel and counted three revolutions until the clock spring unwound. How critical is that setting when re-installing the wheel & airbag? This car is the one year only "91 940SE.
Old Mar 4, 2019 | 08:07 PM
lev's Avatar
lev
You should have locked the clockspring in place before removing the steering wheel with the provided screw. Before reinstalling the wheel, yes, you'd have to rotate it three times around, then lock it with the screw, install the wheel, remove the screw afterwards
Old Mar 4, 2019 | 09:12 PM
amazon2's Avatar
Thanks Lev. I only learned about that secret "screw" from another Forum this morning. I knew it unwound 3 turns when I removed the wheel and I had concluded the whole rotation of the wheel logic but I couldn't find what you just told me when I searched this Forum. So simple when you have the right info. I'm back on the road. Next can of worms is that now the speedo quit and I know that can be one of several things. "Old Volvos never die, just get newer part by part"! TD
Old Mar 5, 2019 | 05:07 PM
lev's Avatar
lev
'91-'92 speedos are the worst, no easy fix... A new one, pricey; a rebuild, pricey; a used one, dicey. Rebulding one yourself, parts are really cheap (diodes) but it takes mini soldering skills and the results are usually not so great. Some use GPS for speedometer.
Old Mar 5, 2019 | 07:27 PM
indeed, my 92 72 speedo conked out, it only read ~ 40MPH even if going much faster... I shotgunned all the potentially sketchy caps, I'm quite skilled at PCBA soldering, still didn't help.
Old Mar 5, 2019 | 08:11 PM
amazon2's Avatar
I have the whole gauge cluster from my wrecked '93 940. Is there a refurbishing outfit either of you would trust? There's no time crunch so I could send this spare one in to get reworked if you think that would be a good way to go. The car is cosmetically so fine I plan on keeping it for the duration. TD
Old Mar 5, 2019 | 09:19 PM
a 93 940 cluster will NOT fit in a 91 940SE (960). completely different interiors and electrics.
Old Mar 6, 2019 | 12:36 AM
amazon2's Avatar
Well that does make sense. The SE is a much "fancier ride". You guys are great. Your wealth of knowledge & experience save me a lot of frustration. I guess it's time to investigate a GPS Speedo. I suspect the odometer isn't working either but I guess that will only make the car worth more when my kids sell it someday!! TD
Old Mar 6, 2019 | 06:06 AM
I've used GPS as my speedo and it sucks, it lags just enough that its surprisingly hard to maintain the speed limit smoothly
Old Mar 6, 2019 | 11:43 AM
amazon2's Avatar
What a shock that old technology is best!! Are you talking about a phone app or a stand-alone GPS speedo?
Old Mar 6, 2019 | 03:57 PM
i've actually used both, a garmin in display panel mode, and a phone based gps running a speedometer app.
Old Mar 6, 2019 | 04:29 PM
amazon2's Avatar
I see some stand alone GPS speedos on eBay for around $60. Have any opinions on going that route? I think some of them require OBDII which off course leaves a '91 Volvo out of the game. TD
Old Mar 6, 2019 | 07:11 PM
lev's Avatar
lev
The clusters are not identical but the speedos are, dimension wise. Unfortunately, the 91-92 are different internally than 93-94-95...
Old Mar 8, 2019 | 11:24 AM
amazon2's Avatar
It occurred to me that since I'm using the ECU from the '93 car, could there be an incompatibility issue there affecting the speedometer? It worked perfectly for the first week after I completed the engine exchange. I could easily put the '91 ECU back in to see if there is a change. TD
Old Mar 8, 2019 | 11:58 AM
speedometer is directly connected to the sender in the rear axle. only thing that cues off the speedometer is the cruise control. the ECU (and ICU) just get engine crank rotation data off the crank position sensor.
Old Mar 8, 2019 | 02:43 PM
lev's Avatar
lev
You could. I don't thing the speedo has much to do with the ECU, let us know... Here si some greatly detailed speedo info:http://cleanflametrap.com/speedo7.html
jtaw45
Jun 3, 2015 08:48 PM
avarvarigo
May 30, 2011 07:00 PM
Alexdfw
Aug 13, 2010 09:19 AM
venture5858
Jun 26, 2010 08:51 AM
NA850boy
Aug 4, 2009 05:24 PM
