Awful engine noise, Volvo 940
Old Dec 17, 2018 | 05:21 PM
92Sedan's Avatar
Default Awful engine noise, Volvo 940
Not my car but one that I've been talking with somebody about, its a 940 with 105k miles. It makes this random screeching/howling when it idle.
Old Dec 17, 2018 | 08:31 PM
Moetheshmoe's Avatar
Engine Noise
I think most redblocks do it eventually, mine did. It's a loose belt. While it's doing that spray a little water on each belt one at a time. When the noise stops you'll know which one it is. Try tightening it and if it still does it then the rubber bushings in the support brackets are cracked, split or distorted, and that prevents you holding a good adjustment. They're pretty cheap
https://www.rockauto.com/en/catalog/...+bushing,11651
Old Dec 18, 2018 | 12:21 AM
lev's Avatar
lev
Most likely a belt, or a pulley, nothing serious. If these miles are real, should be a good find.
Old Dec 18, 2018 | 11:31 AM
92Sedan's Avatar
I'm surprised that Rockauto has Volvo parts, I thought I'd have to go with FCEuro to get stuff! I would test that myself but the cars a few hours away from me, and the owner isnt very familiar with cars from what I understand. If I were there I could probably diagnose it.
If its just a belt would it survive a long highway drive?
Old Dec 18, 2018 | 11:47 AM
lev's Avatar
lev
Sure it would if it's just a belt but make sure it is the belt and it's not really cracked, etc. Also, make sure the miles are right. What year is this car? Keep in mind '91-'92 740/940 speedometers are really bad, rarely survive. I'd run a Carfax to see the miles record besides evaluating the car's condition. A Red Block with 105k is barely broken in...
Old Dec 18, 2018 | 12:21 PM
92Sedan's Avatar
The owner said they'd take it to a mechanic so I'm waiting on that. The year of the car is a 1995, I dunno if it has the Japanese Yazaki gauge cluster or VDO. The owner hasnt driven it much so I dunno what gauges work and dont.
Old Dec 18, 2018 | 01:21 PM
Good idea, check for cracks. If one of the belts is cracked and you tighten it up, it's more likely to snap on you sooner.
Old Dec 18, 2018 | 02:38 PM
its hard to tell in that video, but it does look like the alternator belt is vibrating something fierce, which suggests its too loose.
as Moe said, the rubber alternator mount bushings should be replaced along with the belt, otherwise the alternator sits at a slight angle, and the pulley will eat the new belt. IPD sells poly bushings that will hold up a lot longer. When the belt is off, spin the alternator pulley by hand, make sure its smooth, and has no excessive end play or wobble, otherwise the alt bearings are shot, and its time for a new/rebuilt alternator. if you can rock the whole alternator perpendicular to the direction of the tensioner, then for sure the bushings need replacing.
Old Dec 18, 2018 | 03:28 PM
92Sedan's Avatar
Originally Posted by pierce
its hard to tell in that video, but it does look like the alternator belt is vibrating something fierce, which suggests its too loose...
...its time for a new/rebuilt alternator. if you can rock the whole alternator perpendicular to the direction of the tensioner, then for sure the bushings need replacing.
That could possibly be the case, the car did go through a fresh battery according to the current owner. If the alternators that worn out I dont think the car would make it very long without a back-up battery. Thanks for your input though, along with the others who've commented here.
Old Dec 18, 2018 | 05:07 PM
as long as the battery light on the dashboard comes on when you turn the key on, and goes out when you start the engine, the alternator is at least trying to charge the battery if its dim and/or flickering when the engine is running, then its weak and on its way out. a quick simple test is voltage readings when the engine is running, it should be around 13.6-14.2V.
Old Dec 18, 2018 | 05:51 PM
lev's Avatar
lev
'95 don't generally have bad speedos. But based on all the other info I seriously doubt the 105k miles. Volvos with 105k are pristine. Post the VIN# and I'll run a Carfax on it, may clear up the mileage question.
Old Dec 18, 2018 | 07:13 PM
92Sedan's Avatar
Thanks for the offer, I would request the VIN but the owners been very difficult with my questions, it took a few days and a bit of prodding just to test the heater/AC, which do work but the ACs low on charge. The car was towed to its current spot for what its worth, and its hardly been driven.
Theres a few other faults if they help indicate the real mileage:
1. Aluminum pipe/hose underneath the car has fallen off, I THINK this is the hose that goes from the airbox to an outlet on the exhaust.
2. Neuteral Safety switch is bad, so the car wont start in park.
3. Outer blinker light lense is broken.
4. The car was mostly driven to and from Oklahoma from Kansas, which leads me to question the mileage myself.
Old Dec 18, 2018 | 08:38 PM
that alum hose serves no useful purpose except perhaps in very cold weather, however if you live in a place like California where they smog test older cars like these, it has to be present.
Old Dec 18, 2018 | 09:38 PM
92Sedan's Avatar
Thats true, in the past I yanked it off my 240s and cleared out the airbox just so they breahted better, and to keep the MAF sensor or what not from melting (I forget the part).
Old Dec 18, 2018 | 09:55 PM
yeah, its pretty common trick to wire the flap thermostat closed, then secure the hose in place so it passes smog. they have never removed the air filter or looked under the airbox, just what they can see from topside.
Old Dec 18, 2018 | 11:45 PM
92Sedan's Avatar
True, I found baby jar lids to be effective airbox caps myself.
At Lev:
I'll ask for the vin tomorrow and PM it to yah, I need to ask if hes still taking the car to a shop.
EDIT: I asked for the VIN and I'm still waiting to hear back on it, they've been very busy for the most part.
Old Dec 21, 2018 | 12:57 AM
  #17
92Sedan's Avatar
For now this might be my last update on the car. I havent heard back on the VIN. I explained that Volvos are known for buggy odometers, and when I asked if the guages in the car worked the seller picked up a bit of an attitude with me.
Basically they won't provide the vin, answer any more questions, nor bother looking into the engine noise. I'll have to either bite the bullet and make a 4 hour drive or move on to another car.
Old Dec 21, 2018 | 06:31 PM
  #18
lev's Avatar
lev
Well, not surprising. I am pretty sure based on the info you have shared that this thing has much more than 105k.
Old Dec 21, 2018 | 06:58 PM
  #19
92Sedan's Avatar
You're probably right, I never did get a shot of the dash to verify it let alone a vin, and the owners strange reaction of course. I'll look elsewhere for now.
Thank you for the carfax offer though, if I find another Volvo I might take you up on that offer.
keyturbocars
Feb 28, 2016 09:46 PM
silvermine
Nov 27, 2015 06:23 PM
97black850
Mar 17, 2014 07:28 AM
SDozier
Mar 19, 2011 03:43 PM
MarksS60
Sep 7, 2010 01:18 PM
