Volvo 850 Engine Noise
Old Feb 27, 2016 | 02:11 AM
keyturbocars's Avatar
Default Volvo 850 Engine Noise
My 94 Volvo 850 Turbo Wagon starting making a whining noise. I assumed that it was the power steering pump, but now I am not so sure. Here is a link to a video file that I uploaded showing the engine running with the whining noise.
http://www.key-ideas.com/volvo850noise.avi
I was going to just replace the power steering pump, but then I thought I better double check to see if anyone else recognizes this noise.
Thanks.
Old Feb 28, 2016 | 04:07 PM
I'd take the belt off and spin the alternator and PS pumps to see how they feel and if there is any noticeable noise from either. Also the tensioner pulley.
What condition is the serpentine belt in ??
Also run the engine without the serpentine belt and see if you still have the noise. Could be under the timing belt cover, belt, water pump, belt idler.
Old Feb 28, 2016 | 06:01 PM
Thanks for the reply, Kiss4aFrog. That's a good idea to take the belt off.
Serpentine belt is in good shape. I replaced it around 7,000 miles ago. At that time, I had the engine out on a stand and I was going through things before dropping it back in the car. I replaced all the wear items under the timing belt cover like the timing belt, water pump, and tensioner. I used OEM parts, so hopefully nothing is wrong under there. The noise is probably the PS pump, alternator, or the tensioner pulley bearing. Your idea of taking off the belt should make that clear.
Old Feb 28, 2016 | 07:09 PM
I'd add the AC clutch to the list of usual suspects - may be a good time to use a "listening tube" (a piece of hose you can hold to your ear and place near the various components )
Old Feb 28, 2016 | 09:46 PM
Yup, I forgot the AC
BUT . . . don't make the mistake that a new part is known good or that it isn't about to fail. Much less likely the new stuff is going bad but it can happen.
Be a good mechanic cop, suspect everything until you rule it out.
VanaVolvo
Oct 10, 2012 04:11 PM
VanaVolvo
Sep 28, 2012 07:48 AM
Rafiolo
Jan 1, 2012 02:34 PM
ravenw
Jul 19, 2010 07:12 PM
bsamole
Apr 26, 2009 06:27 AM
