Brake light doesn't work?
Old Oct 28, 2019 | 09:37 PM
Gtallard's Avatar
Default Brake light doesn't work?
I have a 1990 Volvo 745 and the passenger side brake light doesn't work. The brakes are the same as the tail light and that works but as soon as I press the brake pedal, the light turns off instead of brightening like it should. Any ideas? Thanks!
Old Oct 28, 2019 | 11:00 PM
possibly a sketchy ground at the right side tail light assembly ?
Old Oct 28, 2019 | 11:04 PM
Gtallard's Avatar
the other lights work and they have a common ground. the light bulb itself works but just not when you brake.
Old Oct 30, 2019 | 06:09 PM
lev's Avatar
lev
The problem is in the socket to tail light connection. The plastic melts, especially if aftermarket fixture, and distorts the contact points... Look closely at how the surfaces mate, you may have to take it all out, not much space in there to see what's going on...
Pdawg1911
Aug 16, 2016 06:08 AM
Aaron Vance
Aug 10, 2015 08:39 PM
ptrick
Jun 10, 2015 01:13 PM
petree_30
Apr 14, 2011 09:44 AM
carol
Feb 26, 2006 11:16 PM
