Brakes failing
Old Jun 24, 2020 | 02:30 PM
boothisfool's Avatar
Default Brakes failing
okay so recently my breaks have gotten really squishy and go to the floor and sometimes holds the pressure and sometimes doesn’t i think it’s a bad master cylinder because i don’t see any visual leaks and so i bled the brakes today in case somehow an air bubble has made its way into the system and all bled really good except the passenger rear which i can not get all the air out of it i want to make sure it’s bled good and properly before i replace the master cylinder to make sure i’m not wasting money all the help is appreciated
Old Jun 24, 2020 | 02:34 PM
Did you try a power bleeder? That will really help, particularly when you are doing the master (which my bet is ready to be replaced - particularly if you have no signs of leaks at any of the wheels or long lines.
Old Jun 24, 2020 | 03:18 PM
i haven’t tried one yet i was trying to find someone i know with one so i can borrow it and i don’t care to replace the master it’s just if i don’t need to i won’t and also i saw a little bit of fluid on the lines when i was bleeding them but i sprayed brake cleaner prior to seeing it so im waiting to see if it was cleaner or fluid
Old Jun 24, 2020 | 06:01 PM
you don't mention what car this is for, but if it has ABS, bleeding is more complicated and takes longer.
Old Jun 24, 2020 | 06:18 PM
sorry my bad it’s a 1991 240 without abs i’m pretty sure
Old Jun 24, 2020 | 06:33 PM
if it has ABS, there would be a pretty obvious block of metal, plastic, and pipes clearly labeled ABS, in the engine compartment just aft of the battery or the airbox.... like this...
Old Jun 24, 2020 | 06:37 PM
oh, pre ABS 240's have a 'dual triangular' braking system, there's *SIX* brake circuits you have to bleed, two at each front wheel, and one at each rear.
the ABS cars have a standard dual diagonal braking system, with just 4 total circuits.
Old Jun 27, 2020 | 12:12 AM
mine has 8 bleed valves? one on each rear and 3 on the front calipers and mine is not abs
Old Jun 27, 2020 | 02:37 AM
Huh, the pre ABS 240s I've seen only had 2 bleeders on each front, one for each brake circuit.
Old Jun 27, 2020 | 02:39 AM
i could be wrong but i have three on each front it could be something else but i could have sworn it’s three bleeder valves
Old Jun 28, 2020 | 01:27 PM
lev's Avatar
lev
You are not wrong. The late 240 with ABS have only one bleed valve, the earlier non ABS have the multiple valves...
Old Jun 28, 2020 | 01:32 PM
ok thanks do you know how to bleed them i would assume PR DR PF DF but on the front calipers what order would i do the bleeder valves
Old Jun 28, 2020 | 02:24 PM
good stuff here, if your front brake calibers have the dual hoses, follow the non-ABS instructions.
https://www.volvoclub.org.uk/faq/Bra...FluidSelection
  • Bleed master cylinder first
  • On Volvo models with 3 bleeder screws on the front calipers: LR, LF top, RR, RF top, LF two bottom bleeders, RF two bottom bleeders (per Bentley)
  • Highly recommended: use a pressure bleeder as noted below at Brake Pressure Bleeder
philly116
Apr 10, 2013 10:31 AM
78vovlo244
Oct 26, 2008 11:22 PM
jackief288
Jul 21, 2008 08:14 PM
lmyarana
Oct 1, 2006 09:10 PM
