Bullet connector rebuilding info wanted
Old Sep 18, 2015 | 09:24 AM
volvo745newbie's Avatar
Default Bullet connector rebuilding info wanted
Hello all, Does anyone know of a link or tech article on how to replace that clear plastic that surrounds bullet connectors. I went to use the ECM self diagnostic tool but the probe just pushed the wire out of the bottom of the block. Thanks Logan
ps forgot to mention, 89 volvo 740.
Old Sep 18, 2015 | 07:13 PM
shrink-wrap is what I'd use.
its a plastic tubing you put over the connector, then heat up with a hot air gun, and it shrinks til its tight.
those socket/sleeves in the diag connector should have been held in place with a springy 'tab' that sticks out of the connector sleeve and catches on a ridge in the hole they are pushed into from behind.
LiteWait
Sep 12, 2014 04:33 PM
jasstrom
Dec 10, 2013 03:41 PM
S70_Driver
Aug 30, 2010 12:29 PM
blase
Jul 21, 2005 09:44 PM
info2x
Jan 23, 2005 03:59 PM
