Instrument question with 240's
Old Aug 2, 2015 | 04:09 PM
mjohansson2's Avatar
Default Instrument question with 240's
Hello all,
I have returned to the wonderful world of the Volvo, I used to have an '80 240 when I was stationed in England a good car. And a bout 4 weeks ago I bought a mint '92 240 one owner with 130,000 miles on it. Now the car is super clean and the wife just loves it! AC blows cold and the only Quird I have noticed is the temp gauge will got to just under the hot line and then drop back to the middle. I don't think the car is actually over heating.
Also, I wanted to up grade to a full inst package, would love a tach where the clock is, and a real oil pressure and an alt gauge.
So my question is what instrument clusters would just drop in? what years specific? how big a hassle is changing out the gauge package?
Thanks and God bless.
Mike
Old Aug 2, 2015 | 05:24 PM
I've had a sticky thermostat do that, temp gauge climbs up to almost too hot, then the thermostat opens late, and it cools back down to normal.
BUT.. on the volvo 240/740/940's after some point in the mid 80s, the temp gauge on the dash has a 'compensator' circuit designed to keep the needle dead center if its anywhere near normal operating temps, and only read high if its really hot. this circuit can crap out with age and cause bogus readings. on middle run 240's, the circuit was on its own separate little card plugged into the back of the instrument panel, and you could replace this with a jumper and get a linear reading temp gauge (where it will go back and forth around the middle range with driving conditions). however, on late 240s they dropped the separate board and integrated the circuit onto the main instrument panel circuit board. all 740/940 also have this integrated onto the main board. I've toyed with trying to trace out the circuit on my 740T and hack around it but I've never gotten up the motivation to actually try.
Old Aug 3, 2015 | 09:50 PM
92Sedan's Avatar
Tachometers and clocks from any 240 will just drop right in, but the turbo guages require more work.
If you want some extra guages PM me and I'll cut you a deal.
Old Sep 18, 2015 | 10:35 PM
Default instruments
oK how do you make a PM on this board? I would be interested in some gauge clusters, and I just bought another 240! one with a 5 speed manuel
Thanks,
Old Sep 18, 2015 | 10:39 PM
i don't think any 240 instrument panel has a oil pressure gauge or volt or amp meter. you could install 52mm (I think) aftermarket instruments in the square positions just to the right of the panel.
cooper30
Jul 1, 2013 05:21 PM
Phil 850
Jul 17, 2012 09:09 PM
Beau98
Aug 30, 2011 09:50 AM
gasman59
Jan 9, 2007 04:18 PM
Psaboic
Nov 8, 2006 11:52 AM
