A/C compressor overhaul
Old Sep 10, 2019 | 09:31 AM
Zombi's Avatar
Default A/C compressor overhaul
Has anyone tread this path before? My car has 105k miles and perhaps is a candidate for this. When we evacuated the system it started at 30 lbs of vacuum and went down to 27 in shortly.
Old Sep 10, 2019 | 02:36 PM
an AC shop can inject a fluorescent dye into the AC system, and the location of the leak should be evident with a ultraviolet flash light with the car parked in a dark garage
leaks can occur in many places, the compressor, the evaporator, the condensor, anywhere in the plumbing, the connections to the AC reciever/dryer, etc.
btw, 30 lbs of vacuum is an impossible thing as atmospheric pressure is 14.8 PSI, so an absolute perfect vacuum would be -14.8 lbs... more likely it was 30 inches.
Old Sep 10, 2019 | 10:04 PM
lev's Avatar
lev
So, why blame the compressor? You have a leak, find it! 105k is not a lot of miles, my 1992 745 has 240k still on original compressor with R12, still ice cold! I never mess with it!
Old Sep 11, 2019 | 02:56 PM
btw, 'anywhere in the plumbing' includes a cracked hose.
irvgold01
Feb 16, 2015 02:52 PM
zloetakoe
May 4, 2013 03:10 PM
sghokie
Jul 25, 2011 05:00 AM
alexdelove
Aug 13, 2007 12:12 PM
kracunas
Mar 17, 2006 08:46 PM
