a/c problem
Old Feb 8, 2010 | 10:54 PM
940turbowagon's Avatar
Unhappy a/c problem
The car in question is my 1993 940 turbo wagon. I bought this car dirt cheap with some issues mostly electrical.The prior owner liked togle switches apperantly and I don't... Prob is as follows. The a/c was working on all speeds,but I would have to flip a switch he rigged for the compressor to switch on. Obviously I removed it and now do not have a/c. How can this be correctly repaired,please ?
Old Feb 9, 2010 | 12:41 AM
tedv's Avatar
Well, hard to say exactly other than to get in there and fix whatever it was that made the previous inventor hook the toggle, most likely the OFF/ON A/C switch on the control panel. You'll need a new switch, and replace it and wire it correctly. I'd get the switch from a junkyard.
Old Feb 9, 2010 | 01:21 AM
Thanks,that was going to be my first attemp.
Old Feb 9, 2010 | 07:14 PM
Also check the solder joints in the controller they are known to go bad all the time.
You can resolder the joints and usually be good to go.
s70_t5_1999
Jan 22, 2010 11:53 PM
chimmychong
Apr 24, 2008 01:59 PM
volvo_s70
Jan 22, 2008 01:19 PM
toshields
Dec 8, 2007 04:50 PM
