Can't Diagnose ABS system on 93 940
I recently bought a 1993 940 turbo with ~130k miles on it. It had an ABS light on the dash, but I can't retrieve any codes from diagnostic system. Both sockets 2 and 6 yield 1-1-1, but socket 3 doesnt read anything. I also can't successfully reset the ABS light. Has anyone else experienced this problem or solved it?
and, btw, I just checked the wiring diagrams for a 1993 940, and indeed, the ABS control unit diagnostic output should go to block A pin 3.
i found the instructions for 1993 ABS (sorry, can't copy the doc, its copy-protected on a CD)...
looks like i was wrong about memory retention, last 3 codes ARE stored even if the engine is switched off. the ignition has to be on to read them. plug in DLC block A pin 3, press button for 1 second, release and you should get a DTC code flash sequence.
850massa
12-30-2010 05:24 AM
