Can't get my 1984 volvo 240 gl started
Old 04-01-2020, 04:30 PM
on a volvo k-jet the fuel distributor is kinda buried under the intake manifold and not nearly as obvious as it is on Mercedes or VWs with K-Jet... the eaesier thing to see is if the injectors are on a rail and have wires running to them, then its definitely LH.
1990 Mercedes 300E KE-Jet ...
(shiny clean fuel distributor and airflow meter because I'd just taken it all apart, cleaned the distributor and replaced the fuel meter).
  #22
Old 04-01-2020, 10:16 PM
Sulaymaan's Avatar
yes the Volvo doesn't have the fuel distributor it has k jet I believe but I don't see a valve on the fuel rail anywhere to check pressure
  #23
Old 04-01-2020, 10:24 PM
if you have a fuel rail, you have LH Jet not K Jet.
early LH didn't have a valve, you need a T-fitting, and remove the incoming fuel hose, install the T, and connect the fuel pressure gauge to the T, then start the fuel pumps. if the engine is running, you need to disconnect the manifold vacuum line temporarily from the fuel pressure regulator to get the correct reading of 36 +/- 2 PSI.
  #24
Old 04-01-2020, 11:46 PM
Sulaymaan's Avatar
in coming hose meaning the one by the firewall to the fuel rail?
  #25
Old 04-01-2020, 11:58 PM
yes, there's two fuel hoses, one connects directly to the rail, thats the pressurized fuel from the fuel pump. the other connects to the side of the fuel pressure regulator, and is the low pressure return line back to the fuel tank.
  #26
Old 04-02-2020, 02:19 AM
Sulaymaan's Avatar
ok got it so what do I do next
Nevi
2001-2013 model year V70
04-28-2018 08:14 AM
Suzanne4
02-14-2018 09:21 PM
Gazolba
09-19-2014 10:56 PM
lowdown89
05-05-2012 03:49 AM
Quick Reply: Can't get my 1984 volvo 240 gl started
