Changing my oil to synthetic?? Yes or No?
Old Sep 8, 2006 | 06:48 PM
colgate41's Avatar
Default Changing my oil to synthetic?? Yes or No?
91’ 740 turbo 4 door. From what I know it has always used regular old oil. It has about 140k on it now, and I was thinking of making the switch to synthetic oil. Do I need to do anything to the engine before I do this, and is it a good idea? Thanks a lot.
Old Sep 8, 2006 | 07:18 PM
Orlando's Avatar
Default RE: Changing my oil to synthetic?? Yes or No?
G'day mate. I've heard that with the older cars-if you've always used fossil based lubricants, continue to use them. Apparently, if you change to synthetic oils which I heard are thinner and have detergents you could clean out all the slug which is actually acting as a bung and your car could start leaking oil. I don't know for sure though. Just my two cents worth.
Old Sep 9, 2006 | 12:28 PM
That is what everyone says. Some cars leak oil worse from where they already leak.
You will be fine installing it.
Old Sep 12, 2006 | 08:58 PM
crazynlazycolombian's Avatar
mobil 1 10W-30 syn.....thats what im running, would recommend
Old Sep 14, 2006 | 10:20 AM
bli745's Avatar
I have found the "high mileage" formulas a real benefit to the nagging leaks
that 200+K have to live with. I did indeed find higher loss with Mobil 1 and
have been using Pennzoil High Milegae since and my driveway loves it. If you
change oil every 3-4K, M1 is all of throwing money in a drain bucket.
BenHur
Sep 8, 2015 09:29 PM
Arsenal6
Apr 26, 2009 02:34 AM
aruizdelhoyo
Engine & Internal
Jan 15, 2009 09:26 AM
Mnvolvo1
Mar 25, 2008 08:42 PM
Viraaj
Nov 11, 2006 01:23 AM
