compatible rims
Old Jun 20, 2015 | 09:22 PM
thebatpeople's Avatar
Exclamation compatible rims
I am in dire need of a spare tire for my 1991 740 (non-turbo).
It is a 5 lug 15 inch rim.
I have called all junk yards in my area and no one has any Volvo rims at all.
I have found online a few spares but they are for newer models.
So I have two questions:
1)What models of other Volvos have compatible rims/spares?
2)Are there any makes/models of other vehicles rims that are compatible?
Old Jun 20, 2015 | 10:56 PM
The 740 stock wheel size uses a 5x108 bolt pattern with a 20mm offset (you'll see ET20 stamped somewhere on the factory rims to confirm). 940s and 960s have the same bolt pattern but have slightly different offsets (vary by year/model from 15mm to 25mm). 5mm offset would fit the car but you'd probably want to use in pairs except for a temp spare. You can search for used wheels nationally via Cart-part.com and it will search junk yards within a region and you will find used. You can find refinished wheels at collisionwheel.com (probs nicer than what is on the car!). Third option is to post a "WTB" request or search the classified boards in the forum. Last idea is to trade your 740 for an 850 and I'd sell you a spare from mine :-)
Old Jun 20, 2015 | 10:57 PM
lev's Avatar
lev
That car came with a space saver spare but it can take a full size wheel/tire. Best bet is to go to a yard for older cars, like a Pik n Pull, they are plentiful there. You need a 15", a 14" won't do because of the ABS...
Old Jun 21, 2015 | 08:05 PM
a 91/92 740 is virtually identical to a 91-95 940 except the rear trunk if its a sedan, and the seats. 960's pre-facelift (91-94) have the exact same wheel offset, too.
Dex2020
Feb 7, 2019 02:21 PM
drdrp
May 26, 2011 09:01 PM
alexm963
Sep 21, 2006 08:36 PM
WagHag
Apr 27, 2006 06:27 PM
hotsh0t5
Dec 8, 2005 02:28 PM
