coolant issue
Old Nov 8, 2015 | 05:53 PM
jayvolvo740's Avatar
Default coolant issue
Hi. I am experiencing a perplexing situation with my '93 940T (217,000 miles). I recently purchased this car and had issues with the coolant system. I seem to be losing coolant somewhere..., but I am not seeing evidence of it leaking anywhere; such as through hoses, expansion tank or the water pump.Nothing wet under the car either. I have replaced the tank,cap and water pump very recently. When the system is hot the expansion tank will be at just above "MIN" one minute and then empty the next. (When the car cools down, I can loosen the tank cap, and coolant rushes back in to about the original line.) The radiator hoses will be VERY hard. I am not sure if the system is circulating or not. So far no overheating. The heat inside is very good. I don't drive the car far or at all. Thanks.
Old Nov 11, 2015 | 03:32 PM
lev's Avatar
lev
First, eliminate possible head gasket problem by taking a compression/leak down test. If you are getting heat then circulation is fine.
Old Nov 22, 2015 | 07:39 PM
Default coolant issue 1993 940T
To continue with my symptoms. I have recently notice a film of what looks like oil inside the new expansion tank. I have changed the thermostat and upper rad. hose this weekend, and also the oil breather box. I can feel the thermostat open and coolant flowing. After the system heats up, the rad. hoses still get hard, but not as hard as previous. During testing static in my yard I can still notice that coolant is disappearing in the expansion tank, but comes back after I loosen the tank cap. Good heat in the cabin and NO overheating issue. I am wondering what might cause this; head gasket, blockage, or possibly a issue with the turbocharger(oil/coolant lines). Still don't dare to drive the car for fear of doing major damage. HELP! Thanks.
Old Nov 22, 2015 | 09:59 PM
lev's Avatar
lev
Well, again, CHECK THE HEAD GASKET! Do the test!
Old Dec 31, 2015 | 11:44 AM
R2millers's Avatar
You can also pull the spark plugs. If you have a suffient leak in one cylinder, you'll find a very clean, white plug as the water does a good job cleaning it.
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
