Coolant leak, fixable?
yeah, there's a gasket ring between the overhang of the head and the top of the water pump, it looks like its failed. aftermarket ones are notoriously uneven quality.
this one should be decent quality,
https://www.fcpeuro.com/products/vol...o-head-1336255
you're going to need to remove teh pump to replace that gasket, so I'd plan on replacing this main gasket, too,
https://www.fcpeuro.com/products/vol...ne-oem-1378491
if your pump is about 120000 miles or more old, it might not be a bad idea to preemptively replace it, as thats about how long the better ones are good for. recommended practice from the factory was to replace the pump every other timing belt (timing belt is a 60k mile interval)
the pumps come with all the gaskets.
https://www.fcpeuro.com/products/vol...80-240-244-245
joker834
05-15-2010 07:47 PM
