Coolant leak, fixable?
Old Dec 15, 2017 | 08:57 PM
Alex89's Avatar
Default Coolant leak, fixable?
I have a very slow coolant leak and its coming from here...is this fixable, what is that, why is it leaking...
Old Dec 16, 2017 | 01:39 AM
yeah, there's a gasket ring between the overhang of the head and the top of the water pump, it looks like its failed. aftermarket ones are notoriously uneven quality.
this one should be decent quality,
https://www.fcpeuro.com/products/vol...o-head-1336255
you're going to need to remove teh pump to replace that gasket, so I'd plan on replacing this main gasket, too,
https://www.fcpeuro.com/products/vol...ne-oem-1378491
if your pump is about 120000 miles or more old, it might not be a bad idea to preemptively replace it, as thats about how long the better ones are good for. recommended practice from the factory was to replace the pump every other timing belt (timing belt is a 60k mile interval)
the pumps come with all the gaskets.
https://www.fcpeuro.com/products/vol...80-240-244-245
Old Dec 16, 2017 | 08:00 AM
Alex89's Avatar
Ok thanks a lot! I think I will replace it along with seals under the timing cover bc I think one is leaking.
I want to use the OEM parts or at least as good as OEM, is the HEPU good, or should I stick with OEM Volvo part?
Old Dec 16, 2017 | 01:53 PM
pretty sure Hepu and Graf *make* the Volvo branded pumps.
Old Dec 17, 2017 | 08:37 PM
Alex89's Avatar
Thank you again! Thats super cheap for a water pump I expected muuch more.
nealeas
May 21, 2014 02:57 PM
cmayo313
Mar 18, 2011 12:09 PM
joker834
May 15, 2010 07:47 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
