couple Q's 240 sedan
have 89 240 dl sedan , service light is on been on since i got it last summer, now i noticed there is a hole right by my knee is that where the switch is to reset it? also my reverse lights dont work. today at auto zone i took the bulbs and the connectors in and they lit up so i have the right bulb and there doesnt appear to be corrosion on the circuit board , I am thinking could it be that my ex replaced the neutral safety switch and that has something to do with it? or someone had suggested i check the black wire by the console? all the other lights work. i havent had any other problems with the car , its been good to me. im just starting to get into fixing the volvo up a bit come spring. thanks joni
The attachment shows where it is.
Before taking the gear shift console apart test to see if you have 12 volts at the reverse light connector at the bulb. Put the shift in R and turn the ignition to illuminate the dash lights. Don't start the engine. Although the bulbs and connectors checked out OK that does not mean there is power on the car.
[IMG]local://upfiles/4491/EB95F67BE13B43D3B2B8DF14B4A4E9BE.jpg[/IMG]
Mark_Eee
Nov 24, 2014 04:46 PM
anomalousclouds
May 10, 2010 01:26 AM
