Diagnosing a worn out 740 gearbox
Old May 16, 2015 | 05:09 AM
amburu's Avatar
Default Diagnosing a worn out 740 gearbox
Hi friends;
I have a 1987 740 GL wagon which has served well so far.
How would I tell that my gearbox needs replacement? I've been hearing a whining noise somewhere below the gear lever at low speeds and I am sure it is not front wheel bearings as I already had those replaced.
Could it be the gearbox? Apart from the noise gears shift and engage okay; but I would not want to wait until a complete failure.
Any advise is much appreciated.
Old May 16, 2015 | 01:20 PM
this is a manual transmission? does the noise change if you put the clutch in? does it change if you're in neutral and let the clutch out? is it different if you, say, shift from 1st to 2nd or 2nd to 3rd at said low speed ? does it change in tone with road speed, even if you're in neutral with the engine idling ?
92_240_sedan
Jun 10, 2012 10:40 PM
matt01
Dec 22, 2010 10:45 PM
allanburns
Aug 3, 2010 10:56 PM
halcyon419
Nov 20, 2009 12:36 AM
8T9GTA
Nov 24, 2007 09:10 PM
