The dreaded tail light issue....
Hello all, now I did a search of various forums and there seems to be an issue with the 240 as it gets older withe the break lights, is that correct? most likely with the circuit board? and the fix the problem I need to order one from IPD or Volvo right? The previous owner "fixed" my '89 by removing the break light bulbs entirely and removing the warring light from the dash as well. Great fix. Any suggestions? or should I just order a new "board"? Thanks, and God bless.
mike
mike
It is the mylar circuit board that wears out. The bulb socket to the mylar fails. You can hard wire them to the mylar by soldering or solder directly to the wiring harness.
A new circuit board is another option. If you don't do the soldering fix, then yes... buy new.
Good luck
Good luck
newsboy121
Aug 25, 2005 10:58 PM
