Drive line replace/rebuild and center bearing
Old Aug 7, 2007 | 05:04 PM
brother's Avatar
Default Drive line replace/rebuild and center bearing
Well, I'm surprised the joint in the middle of my driveshaft hasn't already popped out. Its ground itself almost all the way out of the joint.
I'm wondering how tough it is to replace the joints and center bearing...I just got this 1978 245 station wagon, but I've only worked on 740's before, and never done a driveline.
Any advice, links, and warnings would be severly appreciated.
Also, I have to replace the brake pressure warning sensor (little plastic plug) because its leaking fluid. This seems easy enough, but when you start thinkin stuff is going to be easy, sometimes that puts you on the highway to the dangerzone, and fast. Any heads-up on this too?
Thanks
fsmo
1998-2000 model year V70
Oct 1, 2014 11:34 PM
lediii
Aug 4, 2010 09:35 AM
ss~zoso~ss
Mar 10, 2009 09:38 PM
Kaybihiak
Dec 4, 2007 11:51 AM
MarcP
Jan 8, 2006 11:13 PM
