Driver side door handle
Old Mar 9, 2016 | 06:05 PM
inbinder's Avatar
Default Driver side door handle
My 83 240 GLT wagon is doing just great, however, the driver side door handle
pulled out this morning. I can't seem to actually get it to mate flush to the door.
Is this a terminal blow? It can line up and look mostly ok, but then the slightest bit of pressure pulls it out.
This is before i pull up and re-seat it. It's---natural state if you will.
Old Mar 9, 2016 | 06:22 PM
been awhile since I've taken one of those apart, but I think that part that fits into the door has like a 'T' end, and you have to rotate the whole handle assembly 90 degrees to get this "T" to fit into the slot in the door... maybe you could fab something from a bit of appropriate thickness aluminum, screwed onto the end of the handle, and filed/ground to fit into the key slot ?
Old Mar 9, 2016 | 06:29 PM
inbinder's Avatar
Yeah, I was just looking at it again and it does seem like the rotation is all wrong.
Oof. That sounds like a good way to spend a saturday.
Old Mar 12, 2016 | 10:37 AM
lev's Avatar
lev
The metal on the door where the handle inserts may be distorted. You may be able to straighten it once you have the panel off and see the damage...
mphilleo
May 11, 2022 12:18 PM
SrinathKN
Feb 3, 2012 06:41 PM
maine1946
Jan 14, 2011 08:48 PM
TMac
Apr 23, 2009 09:21 AM
volvogirl46
Apr 26, 2007 01:58 PM
